strocket
- June 6, 2004
- San Antonio, TX
- 01 sport trac
Well heres just a brief story on what has happened. I have a 2001 Sport Trac and a few weeks ago my tranny started to flare really bad going from 2nd to 3rd. I would have to let off the gas to get it to shift. I thought that it was just the normal flare that all of these transmissions have so I didnt worry about it. Well yesterday it did it again, let off the gas, it shifted, and I was on my way. Well I pull into the driveway and I couldnt even get all the way up. Almost as if I was in neutral but it was still gripping a little bit. So I put it in 1st and drove up. Not knowing what had happened I wanted to go for a drive around the block so I put it in reverse to back out, and I didnt have reverse either. So I just rolled down the drive way and put it in first, and then shifted to 2nd, and then to drive. Everything worked that time so I drove around and back into the driveway. Then I tried reverse again it worked. Put it in drive to go back up the drive way and it was the same as it was before. So I used 1st again, but then that had the same kind of slippage. So I tried 2nd, and that worked. Then I parked it and came on here to start reading as to why it was doing that. After reading I figured that the sep. plate had a blown gasket. So I decided to go ahead and do the tsb kit, new sep. plate, sonnax boost valve, superior shift kit, and also the sonnax end plug kit. Today I went to remove the valve body hoping to find a blown gasket... but no blown gaskets. So then I thought maybe it was the epc solenoid. Well when I set the VB on the work bench to take them out and test them I noticed that There were brass and aluminum shavings. Not alot but enough to know that the shouldnt be there. They were on the sep. plate about 2 or 3 inches to the right of the TCC and EPC solenoid. What do you think those shavings could be from? What would have caused the tranny to just start shifting like that?
Thanks in advance for your help DR. Glacier
