$9 hooks will wreck your sheetmetal
Ford just generally have low hanging sheetmetal (compared to Chebbies, anyway). I bought two sets of those 10K lb. hooks, glad I didn't spend too much $$ on them. They're going on receiver inserts at this point.
Look around under your front and rear bumpers; there's no where to mount them and NOT have the tow line impinge on bumper (very weak and flimsy) or sheetmetal (expensive to fix).
Shoot, a friend of mine has a Cherokee Limited, his front tow hook mouting point took out the plastic bumper cover when he yanked a car out of a ditch - that was FACTORY!!
The Ford factory ones on the new F150's and the SportTracs stick out past the front bumper; the rear one on newer Explorers does as well. The fronts I've seen looked OK, that rear factory Explorer hook looked WEAK.
One of the advantages of home brewing a Chevy solution is they're cheap and they stick far out away from sheetmetal/bumpers.
Best solution is a receiver hitch on the front and rear; put the hook/loop on a reciever insert, then it's centered and across both frame rails for maximum strength. I'm getting Duff receiver bumpers front and rear for my Ranger, the Reese front receiver is on it's way for the Explorer.
Best,
Brian in CA
PS No matter how careful offroad you are, you WILL get stuck at some point, and the investment now WILL pay off in the future.
