go sputter sputter go | Ford Explorer Forums
v_dawg_420_69
FORT CARSON CO
98 EXPLORER
ok i got a 98X and i just moved to clorado and when i got here it started missing horably while idling and driving i replaced the plugs and wires any ideas what could be the problem
Try cleaning the IAC (idle air control) valve -- its easy and cheap. Also, check the vacuum hoses coming out of the intake plenum and look for any leaks
Use the Search feature of the forum if you're not sure where the IAC is located or how to clean it.
thanks the iac worked out great no more sputter thanks
have you looked at all the vacuum lines.... does it stop when you rev the motor? If not it is most likely a vacuum problem. It also could be the egr valve. if the check engine light is on do a diognostics test. you can get it checked at an auto parts store.
