Going to replace clogged fuel injectors.(questions) | Ford Explorer Forums
glued2it
Tulsa OK
96 xlt
I did an engine swap(my first) in a 96 xpl 4.0
Seems that I have 2 clogged injectors. I tried a can of seafoam in 10gal of gas with no luck.
I have the old injectors off the seized engine and figured I would just use those. just change the o rings?
I'm going to replace the lower intake gasket while I'm at it.
Should I remove the whole intake and replace the gasket to the block or just the one to the fuel rail?
I'm guessing since the plenum gaskets are basicly o rings (no paper gasket used) that this set is the ones for the fuel rail.
Link 1
Or do I need to get this set?
link 2
