Elcapper
- February 17, 2009
- Seattle, WA
- 1998 Explorer 4.0L
Hi, it's been a long time since my last post!
Just wondering what I should expect my MAF lb/m ratio to be? Mine read out at .75-.90 tonight at cold start about 60 degree weather. Ex didn't start earlier tonight which reverts back to an old issue I had with a no-start condition. It would turn over, sound like it was about to kick in, but nothing. Finally got it started by pumping the gas a little tonight. So that makes me think it's an airflow issue. Last time I had this issue early this year I cleaned IAC, checked relays, replaced fuel filter, cam sensor, cps - then moved it on a flatbed and it started at the end of the trip. I never touched the MAF though so just wondering if that is a decent MAF reading. Plan to clean it tomorrow and hopefully that will do the trick. I think I usually idle at about 1000 rpm's.
Sorry, I searched for the info but maybe I was searching the wrong terms or something because I couldn't find anything. Or is it just the voltage that matters?
Any help appreciated! I've read a ton of the no-start threads over the last year since I never found out why mine ended up starting eventually (wasn't after I replaced anything, just out of the blue).
Anyway, thanks!! '98 OHV
Rory
Rory
