ophidia
- March 14, 2007
- Fargo, ND
- 1999 Mountaineer
This is a 1999 Mountaineer 4x4 4.0L SOHC. I'd noticed recently a strong coolant smell, and the coolant bottle was almost empty. I filled it on Thursday, and today it's almost empty again. I just noticed a good sized spot of coolant on the ground beneath it. After looking around with a flashlight, crawling underneath it, etc. it looks like it's running down the bellhousing and has soaked the whole oil pan. It all seems to be coming from the driver's side of the engine.
I felt down the back of the engine as far as I could get my arm stuffed back there, and didn't find any wetness. When I look in the driver's side wheel well, I notice the first wetness behind the exhaust manifold around the rear cylinder on that side. I can't see where it's coming from.
Recent work done on the vehicle: I replaced the upper intake manifold gasket and the thermostat a couple of months ago. Two weeks ago, I replaced the alternator and tensioner. I didn't notice any coolant smell and loss then. This has shown up w/in the past week.
I don't see any wetness around the water pump, either from above or looking up from below. If it were the water pump, could it present like this? If the thermostat housing had started leaking, could it show up like this? It looks like there could be some dampness around it, but I don't see anything pooling on top of the engine.
I'm not really sure where it could be coming from. Any ideas?
