got a little problem | Ford Explorer Forums
In2Deep
Lexington, Ky
91 XL 4d 4wd 5speed
i noticed today while doing the normal tune up stuff, that there was no rad. fluid in my radiator. naturally i topped it off and off i went. i checked it 3 hours later, and bam...no fluid. now i'm not stupid, so i traced where it was leaking again by putting more in and leaving it running. i'll be damned if it isn't coming from the freeze plug on cyl. #6!! wow, is this common? and is there any easy way to replace all the freeze plugs without removing the engine? if i have to i will, but i'd go ahead and rebuild it totally if i had to take it out. anyway, any help would be appreciated. thanks, mike
Actually they can be replaced without pulling the engine..a real PITA...but doable....
