Governor | Ford Explorer Forums
Governor
karnage
92 explorer xlt
I was looking at transmissionpartsusa and couldnt find a new governor part number.They list the bigger weight and the governor sealings.Should I just put new seals in the governor instead??I rather would put a new one in.Also a part number for the billet pilot bushing would be nice from sonnax.Couldnt find that one either.
They sell more items than they have listed. If your governor isn't worn out you could just use the upgraded weight. Email or call them to see if they have the entire governor. The Sonnax crankshaft to flywheel spacer part # is 56000-CS6. This is for the 6 hole spacer. The newer ones use the 8 hole spacer with the 8 at the end instead of a 6.
