Gps nav question | Ford Explorer Forums
Gps nav question
shaft
whittier cali
2002 sort
ok i have a indash lcd tv/dvd player is it possible to connect gps to this and if so what do i need to buy and how do i hook it up.
Does your dvd player have an auxilary input on it?
Well if it has an aux. input. It should be as simple as finding a connection piece to your dvd player from your gps unit. The dvd player if I am correct should then send the signal to the tv from the aux input when you switch the setting from dvd to aux.
WORD!
Like CPL says...the only 'gotcha' would be if you had a touchscreen--and needed the 'touchscreen functionality' with the GPS. You would NOT get that without a unit made for your touchscreen. Other than that--you'd get everything else.
