wraheem
- November 1, 2010
- 2002 Mercury Mountaineer
Hello All,
I've had a very interesting four months with my 2002 Mountaineer. About a year ago when making a sharp right turn I heard a very loud clunk sound. I did some searching and it sounded like it was a drive shaft issue. I put this off for a while and noticed that when parking that my wheels were "burning rubber" and I was jerking around turns.
About four months ago on the highway I heard a noise that sounded like I had a front right flat tire. I pulled over but no flat tire. A security guard told me it sounded like the hub was bad and I might lose the wheel.
I took it to Firestone to have it checked and told them I suspected it was a drive shaft problem. They said it was the right hub and didn't see a problem with the drive shaft. I let them do the work to repair the hub.
About three weeks ago I started hearing a similar grinding noises with some serious vibrations on the left side, so I took it back. They said it was a lose bolt in the differential that was causing the drive shaft to jump around. I had them remove it (drive shaft) but noticed a clanking sound that they said was due to bushings coming out of the differential (Keep that in mind).
I started noticing a low thump when braking at low speeds but couldn't see a problems with the brakes, rotors etc...
This weekend when staring out of a trip down south I noticed a grinding and metallic clunking sound when I stopped. I pulled over and raced around a parking lot trying to pinpoint the issue. I also noticed some clanking sounds when I drove away, but I assumed that the differential came lose again due to the jerking when I stopped. I went ahead on my trip thinking that maybe it was time to change the brakes again. I didn't here the noise again and thought that perhaps the problem "went away" (wishful thinking) but I was able to reproduce the issue. Whenever I travel over around 40MPH and need to come to a quick stop, the clanking grinding sound happens.
I took the wheel off after looking at the excellent sticky post about changing wheel bearings but couldn't find anything wrong; calipers tight, pad and rotor seems fine, and a barely noticeable play trying to move the lug nuts/wheel bearing up and down, and none left to right...
I'm at a loss at what's wrong, and I don't really want to take it back to Firestone, in between getting hubs and shafts worked on, I also had to get the alternator replaced.
Because the drive shaft is already gone on the driver side, I'm pretty sure I can change the wheel bearing assembly if that's the issue. I know I can change the brakes/rotor/caliber if that's the case...
Any help would be greatly appreciated!!!
Sorry for the novel but I needed to get all the pertinent info in here...
