Grinding noise from front diferential when backing up | Ford Explorer Forums
Explorer75
FL
I have this grinding noise coming from the front differential when I´m backing up and there is a hole or some resistance (not a flat surface). For example when going out a drive way in reverse when I get past the street water channel (don´t know if that´s the name, sorry).
This truck is 4x4, the grinding noise is heard with the 4x4 in auto. When it happens I don´t see the 4x4 illuminate in the dash.
It might be worthwhile to have your dealership check this out, Explorer75. What's the current mileage?
Crystal
My mileage is 36,625. Not that much.
I´ll will check with my dealer.
Thanks
With that mileage I believe you should still be covered under the 5 year powertrain warrantee.
