Grinding noise while turning | Ford Explorer Forums
Trefty
99 XLS
Hey all. Recently I've noticed a sort of grinding/rubbing noise from the front of the vehicle but only during left turns. I'm thinking this could be the driver's side wheel bearing/hub assembly, but not sure. How do you properly check the wheel bearings? Jack the vehicle up and check for up/down play in the wheel? Thanks.
