cnsheets
- September 7, 2011
- 2011 Explemoner
Should my brake rotors already be grooved? I have never had a vehicle that the rotors grooved like this before unless I let the pads get really worn and low. Vehicle has 15K miles on it. Could this be related to the brake squeal TSB? reason I ask, is that a couple times in the morning when its cold, I get a slight squeal, but nothing like others have reported, it only happens breifly and goes away. My concern is more with the wear of the pads and grooved rotors. I certainly do not want to be replacing rotors prematurely. You can physically feel the grooves when you run your fingers across the rotor, almost like running them across a concrete sidewalk that has a broom finish. All 4 rotors have the same grooving with one of the rears being slightly worse.
