geosnooker2000
- March 29, 2007
- Somerville TN
- '10 Eddie Bauer V8 4x4
Vehicle in question: 1996 X EB 4.0L auto Tranny 4X4 with 300,000 +/- miles
Last year in the spring (?) I had my tranny rebuilt by someone I now do not trust. I think he did NOT use new parts to rebuild, just bought a used one he new to be in working order, and traded out parts into my tranny housing. At first it didn't shift into OD, so he tightend up on a band, and it shifted fine after that.
Fast forward to 4 or 5 weeks ago.
It started slipping out of gear (or down-shifting, hard to tell) in 2nd or 3rd grear on medium acceleration. As the whether got colder it stopped doing it. But when it is really cold in the mornings (below 35deg F, let's say), when I start the truck and pull it down into drive and/or reverse, it takes up to 6 or 7 seconds to engage into gear. As the truck warms up, that problem goes away. However, as the truck gets hotter and hotter, or if it's a warm day out, the truck refuses to stay in OD at highway speed (say 55). Especially if I have to drive a distance that has me running it for an hour or so. When this happens, it is usually accompanied by a flashing OD light.
2 weeks ago, new problem. It starts idling very rough. So rough, in fact, that I have to pull it into N at stoplights and hold my foot on the gas, or it will die on me. If I don't (and here's where I am wondering if it's related to my transmission) it will jump between 500, and 900RPMs and the truck will surge with it. Even with my foot on the break, it will try and surge forward. Strong. About 2 days after this started happening, I dropped by AutoZone and got the codes pulled. Guess what? No Tranny codes. Here they are....
P1450
P0401
P0171
P0153
By the way. All this without a "check engine" light.
So my question is, should I start with the transmission problems, or the "running rich" problems? 'Cause it's hard for me to believe I get 4 problems in the engine compartment all within about 2 weeks. Could a transmission cause all this?
P1450
P0401
P0171
P0153
