- February 15, 2010
- Charlestown, RI
- 2014 Escape SE
Thanks for the info.
The fogs arrived yesterday. They seem to be good quality. Now that I can hold them in my hands, I have a better idea of what I'm up against. I will check the local parts stores for connectors.
I'm going to bench test them before I install them. Since these will be replacing the cheap Wally World fogs I had installed, the wiring is already in place for the fogs. I need to do the wiring for the halo's. Since I plan to use the halo's as DRL's, I need to find somewhere for the relay to tap into that is only powered with the key on.
I also need to get some relays, etc.
Something tells me that Sandy is going to put a damper on the install.
I will keep you posted and get some pics up!
Thanks again for your help - Rondo
