hard starting | Ford Explorer Forums
hard starting
mike0179
99, xlt
HI every one!
I have a 99' Ranger, 4.0 that has a hard time starting when the outside temp is below 30 degrees and it sits for several hours. I have replaced the battery and cables, iac, iat, ect, fuel filter, cleaned the maf, changed the plugs and wires, and lower intake gaskets, had the coil tested. it will start and idle realy rough for 10 to 20 seconds and is fine after that. My mechanic tested the pressure for leak down and stuff and said it is fine, but he never had a hard time starting it. ( it was in a garage) Could the pressure regulator be causeing low pressure only when it is cold and it is haveing the problem? I cant hear the pump prime for 2 sec. should you beable to for sure with this model? I dont hear it when it is running either however. Some times when its really cold out it will start, sputter and some times die. on restart she fire right up. Once in a while it will start rough when it is warmer out ( low fifties) it seems like its always moist out durring that instance. thanks to all.
mike
Your mechanic can't figure it out?
That's classic! Well, I'm no tech, but hopefully you'll find an answer here. My repetitive response is always, what type of fuel do use use? Brand of gas, any additives, proper octane? Thanks! :)
well the check engine light dosent come and and I replaced the relays today and no go.
Today when i started it it fired quickly but stumbled for about ten sseconds and then like someone switching a swithch on it jumped to perfect. i guess i going to have to check the pessure whie the problem is happening considering it checks out under normal conditions. thanks for th help.
mike
