Raceit
- August 28, 2000
- Overland Park, KS
- '91 Explorer 2DR 4WD XL
Well I'm 99% mine is shot. Or at least stretched out beyond it's normal limits. My '91 has got right around 208,000 miles on it. The valve train was completly replaced about 20 or 30,000 miles ago and has been running fine. However I didn't know at the time the timing chain was an issue...(mainly due to the noise from the lifter tick).
Right now I get horriable gas milage and a metal type ratteling sound if the engine revs up...say letting off the gas going down a hill. It's not a lifter noise since I know what that sounds like. It's almost like what a blown cat would sound like. But louder and a bit faster and dependent on engine speed and load.
I have a Haynes and a Chiltons shop manual and I can't tell what all needs to be done to replace this thing. One says the oil pan has to be dropped and then I see a picture that the lower intake manifold was removed. Obviously I'd like to get away with taking the least amount of hardware off.
From a Chilton manual on CD-Rom it just starts you out taking the front engine cover off. Doesn't sound too bad once you get the belts and stuff out of the way. But do you have to remove the pan or intake manifolds to let the front engine cover come off?
I think that's about it. Should I replace anything else while I'm in that far? Water Pump?
Also can I get a "jawed puller" from a auto parts store? Are those cheap?
TIA
TIA
