funnyperson1
- May 24, 2003
- NOVA (aka Home) for Summer, Blacksburg, VA (aka VT) for Spring/Fall
- Explorer 96 XLT
My 96XLT burns both coolant and oil at decent rates, I have to refill (depending on how much driving I'm doing) every 1-3 months.
When my dad had taken it to Ford to get normal fluids service, Ford told us that the truck burned coolant and that it was possibly a failed head gasket or a cracked head. They said it would cost from 1-3000 dollars to fix it.
We had another mechanic look at it and he said it burned coolant for the first 15 minutes and then stopped. He indicated that there was a small leak in the head gasket and that we should not worry about fixing it as long as I keep an eye on the fluids.
Now if its a cracked head that would take a couple thousands of dollars to fix, then I would probably try and sell the truck, seeing as it has $153, 000 miles on it and is probably worth around $2-3k in good running condition.
However, I was wondering if the second mechanic was right, and how much it would cost to get a head gasket done in the Southwestern VA area. If $500 or lower I would like to fix it.
What are your thoughts? Would fixing it help gas milage/power (I am currently getting 14/18 mpg and power is horrid especially when the car first starts up)
Thanks for the help in advance
