Head Lamp Bulbs? | Ford Explorer Forums
Head Lamp Bulbs?
PJUSTICE2650
Florida
2002 Explorer XLT
Phil Here. Please help me with the type and part number of the head lamp bulbs that are on my 2002 Explorer XLT V8.
Looks like I have two type bulbs in each housing, One is for low beam and one is for high beam. I can't figure it out? Manual calls for 9007 but the bulbs on line are high and low beams in one bulb? I have two separate bulbs..........
Thanks in advance...
2002 Ford Explorer XLT V8 Phil Justice
I wouldn't worry about what is there (edit, apparently 9006 answers your question)-- just go to your local auto parts supplier and see what they have for you. I recently went to O'Reillys and got two new low beams and put them in -- big difference. I hated paying $ 50, but after seeing the results, I wish I had done it sooner. And yes, the 2002 has separate low and high beam bulbs. Here's a link to the ones I purchased -- http://www.oreillyauto.com/site/c/d...-1&keyword=headlight+bulbs&pt=01576&ppt=C0010
You must have the wrong manual, the sport 2 door models and sport trac (truck bed) models have the single duel filament bulbs, the 4 door models use 2 separate bulbs.
Low Beams:
$8.88 Pair | https://www.amazon.com/SYLVANIA-XtraVision-Halogen-Headlight-Contains/dp/B0031HEIDY/
$8.88 Pair | https://www.walmart.com/ip/Sylvania-Xtravision-9006-Lamp/16913668
High Beams:
$13.59 Pair | https://www.amazon.com/SYLVANIA-XtraVision-Halogen-Headlight-Contains/dp/B0031HI0HY/
$9.02 Each | https://www.walmart.com/ip/Sylvania-9005-XtraVision-Headlight/16913633 (For some odd reason Walmart don't sell 9005 in a pair package)
JUNK, I returned mine to Sylvania for a refund got XtraVision and couldn't be happier.
Here is a review copied from Amazon:
White ricer bulbs like the tinted SilverStars tend to fool the human eye into thinking that the whiter light is brighter (especially in a dark environment like an unlit highway) while in reality the yellower lights tend to get picked up more readily by the human eye and are brighter.
Most, if not all, vehicles are equipped with Long Life 9008/H13 bulbs from the factory. Long Life usually means the bulbs were designed with filaments and gas mixtures designed to extend the duration at which the light output remains usable, approximately 800-1300 hours in a laboratory environment. This is in comparison to 2500-5000 hours from HID capsules (D1/D2/D3/D4) which cost $100-$250 per capsule to replace. In addition, white LED headlights/foglights last approximately 25,000 to 50,000 hours.
Sylvania does not keep it a secret that their SilverStar and SilverStar Ultra line of headlights are not designed for longevity. According to Sylvania for their 9007s, their SilverStar lasts 150 hours, the SilverStar Ultra lasts 200 hours, while the XtraVision lasts 375 hours. The 9008/H13 standard bulb can go up to 1000 hours, while the Sylvania SilverStar 9008/H13 is rated at only 325 hours and the 9008/H13 XtraVision is rated for 500 hours.
In the SilverStars, the gas mixture and filaments were designed to compensate for the loss of light transmission from the filter (tint) on the bulb glass. The SilverStars are essentially "ricer" bulbs designed to make the color temperature appear near 4000K (HID white) but this costs you lifespan.
The 9008/H13 XtraVisions are rated for about 500 hours and do not have any lens filters to change the light color. 500 hours is on the short side of the OEM Long Life spec but it is a good balance of lighting power and lifespan. From my experience, they will last at least 3-4 years of normal use (about 30 minutes every workday). Daytime Running Lights and automatic headlights SEVERELY reduce bulb lifespan because they keep the bulbs running at full voltage whenever you use the car contrary to popular belief. In addition, headlight bulbs are rated at 12.8 VDC, which means that the 800 hours was obtained from testing at 12.8 VDC. Running the bulbs at a higher voltage, like the 14.0 VDC that most charging systems produce, will dramatically reduce bulb life. So this is not a surprise that SilverStar owners are getting 3-6 months of use out of their bulbs.
I have used XtraVisions on 3 different cars over the past 7 years and have the utmost confidence in the lighting power. They are still halogens and produce a 3200K "white", but there is a DRAMATIC difference from factory Standard or Long Life 9008/H13s. They make all reflective objects light up, and I can see a bit farther down the road. I've tested GE Nighthawk 9008/H13s and they produce a slightly whiter light with about the same light output, so either the XtraVision or GE Nighthawk 9008/H13s are the best halogen upgrade.
The ultimate lighting solution would be a street-legal HID upgrade, which is cost prohibitive for most owners and requires a lot of work to install. The next best thing would be XtraVision bulbs.
Pros: The best bulb upgrade you can get with a decent lifespan (about 800 hours). Totally street legal, and a big improvement over Standard or LL bulbs. Can be purchased at discount prices.
Cons: Still produces a 3200K halogen "white" which is yellow compared to HIDs. Confusing marketing causes most people to buy SilverStar / Ultra bulbs instead.
^ They are adequate for MY needs and I'm going on five years using SU 9007's. YMMV.
And yes, JMO. Done.
^ IMO they are adequate for MY needs and I'm going on five years using SU 9007's. YMMV.
And yes, JMO.
How old are you? In my 20's I liked "whiter" light but now in my 30's I can not stand it. Don't even get me started on all the new 6000K LED street lights going up, I'm going to have to wear blue cut glasses at night.
Also, it does not snow where you live, whiter light on white snow creates glare.
@fordysenior Oreilly's (and AutoZone, Advance, etc) are the biggest rip off places on earth for non parts consumables. Most are all $10 or more overpriced.
@PJUSTICE2650 How are your lenses? Being a 2002 and in the south I'd imagine they'd be quite oxidized by now. I had to use this kit to fix mine.
https://www.walmart.com/ip/Mothers-NuLens-Headlight-Renewal-Kit/36030674
I don't really trust reviews -- who wrote them, how honest are they, are they getting paid?? I've seen recent reviews on restaurants, positive reviews, AND the restaurant had been closed for two years. Plus, how many people spout 'facts' with no proof -- MANY.
I live rural, and I live in snow country. I drive on unlit roads all the time. I like my bulbs, I feel as I could put a chair out at their reach and sit and read a book.
Since I live rural, shopping is difficult to do. I also pay more for gas because of it, but I'm not about to drive 140 miles just to get cheaper gas.
But I do need bulbs for my other vehicle which is not driven at night as often -- I'll try those cheaper bulbs. My vast experience in product purchasing tells me I usually get what I paid for -- and cheap is not worth the money.
One man's wine is another man's poison
Phil Here, Thanks Guy's. Tech Guru. My Plastic housing lenses are perfect, I polish them once a month. I only want to change out my bulbs because I don't like the yellow look that they have. I want bright White headlights, not Blue , not Yellow, or any Other color. I would like the white bulbs to be in the 3500 to 5000 white color range but I can figure that out for my self.
PS. It doesn't Snow where I reside....................
Again, Please. Please fill in the blanks for me?
High Beam bulb #_________
Low Beam bulb #_________
2002 Explorer XLT V8 Phil Justice
highs -- 9005
lows -- 9006
High Beam bulb #__9005___
Low Beam bulb #__9006___
Give XtraVision a try first, they're quite white when compared to 10 yr old long life bulbs.
If not I would go with GE NightHawk, they have a faint blue tint on them kind of like the old Reveal household light bulbs.
If you're not constantly flipping high beams on and off in the city I used to run HID's in my high beams when I lived in the middle of nowhere and didn't need to turn them off so much.
Also, something to consider, the HIR mod to use brighter HIR bulbs.
http://store.candlepower.com/mohirbuba.html
Well I don't think anyone would be paid to recommend the cheaper product from the same company that makes the expensive version.
If you're going to run SilverStar Ultra's in the middle of nowhere I'd highly recommend keeping a set of spare bulbs in the vehicle.
Have you considered going HID on the high beams? It's quite awesome, like daylight in front of you.
These are mine but I took them out when I moved in town:
General Info for everyone:
SilverStar Ultra & XtraVision
SilverStar Ultra causes some Blue reflections:
Passenger Side XtraVision , Driver Side SilverStar Ultra
SilverStar Ultra Low and 55w 4300K HID High beam
@TechGuru
http://store.candlepower.com/mohirbuba.html This stuff actually works? Often wondered. The lenses on my '93 Cobra were pretty bad, and I wonder if better material is now being used? Cobra is history, so no need to evaluate, just wonderin'. My 2004 has never had a front (or rear) bulb replace, so went through thread for info only. A lot of agreement and disagreement, lively place tonight. No comment on the bright, blue headlights I see today, I'm already in plenty hot water enough! imp
UPDATE -- I bought the XtraVision and installed them in my 1999 F150 -- can't tell the difference from the new bulbs to the original bulbs which are date stamped. Waste of money.
Yet, when I used the Silverstar Ultra in the Explorer, there was a noticeable difference and improvement
One mans wine is another mans poison.
Reviews are just peoples opinions...
I just swapped the stock for superstar ultra and no difference to me.
Installed a 25 inch light bar under my grill and its the best thing I have done in regards to lights...
Amazon by far has cheapest prices.
Even my idle air control valve was cheapest on Amazon.... Compared to rockauto and other places
Rockauto all the way for the best prices you will find and good selection too on things like bulbs and plugs and coil over boots. You will be shocked how much cheaper than prices mentioned above
Example -- Oreilly for an axle nut is $30. RockAuto or even Amazon, about $8 each
a 1999 F150 has crappy diffuser lenses. Your first upgrade on that should be some new clear lens fixtures before worrying about bulbs. Bluer bulbs like SilverStar cause a lot of glare for other drivers when used with diffuser lenses. Not to mention looks dumb on them since the "HID" look one is trying to get using bluish bulbs is canceled out by the fact that no HID's use diffuser lenses.
http://www.ebay.com/itm/Ford-F150-1...ht-Clear-LH-RH-Replacement-Lamps/171917896181
RockAuto has some too (each side sold separately):
http://www.rockauto.com/en/moreinfo.php?pk=707253
http://www.rockauto.com/en/moreinfo.php?pk=707250
