Head light problem (no low beam). | Ford Explorer Forums
mga
Southaven, MS
When I pull the headlight switch I only have head lights on Hi Beam. Could the problem be the Multifunction Switch?
Yes, that's a very common problem (In the 2nd gens, not sure about 1st gens)
I would also check the wiring, fuses, and bulbs. Test the connection at the bulb, see if your getting power
I had your same problem when I put in my HID's. Turned out to be the fuses for me and I just moved up from a 10 amp or volt (forgot) to a 15
