headlight/domelight switch problem | Ford Explorer Forums
herd77
2002 ford explorer
need to ask if anyone has run into this. My wifes 02 Eddie Bauer had the rotary part of the headlight switch going bad. I work at an acura dealership and swapped out a switch assembly(whole part, headlight/foglight,domelight) from a wholesale unit that was fine for the headlight operation. Did not notice until after that the puddle + domelights did not come on when unlocking the car unless the domelight dimmer switch was moved all the way to the end of adjustment. Then the puddle lights and domelight came on when entering, but had no instruments lights unless I adjusted the dimmer. Is this a switch or wire harness issue. I did notice the harness was very tight to remove the switch on my car versus the donor car. I hope someone can help
