Headlight Problem? Need Help? | Ford Explorer Forums
Data804
1994 Ford Explorer XLT
My headlights are flashing on and off. It only happens when i have my high beams on for a while. Is the Relay going bad and if so where is it?
Hello.............
might be a hi beam relay swap it with the low beam ones and see if the problem is still there
Where is the Hi-Beam Relay exactly?
i belive its under the hood
just look in the fuse box under the hood under the box cover there should be a diagram to tell you what fuse and what relay are for what
Check out the links from my signature line, it will take you to a stockpile of pdf files with wiring diagrams, component locations and diagnostics for our Explorers
