headlight problem | Ford Explorer Forums
headlight problem
mikedog12
chicago il
96 eddie bauer
Hey guys,
I having a problem today All sudden one of my headlight passenger side and both my fog light went out I check my fuses all them are good the high beam will work but not my low beam. PLEASE HELP!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!! !!!!!
dID YOU EVER FIGURE THIS OUT i HAVE THE SAME PROBLEM Oops caps lock
I bet both of you guys have the extra center console module with the "light out module" LOM. Most came on the Eddie Bauer and Limited edition as a option. They are known to have problems with the internal circuit board with some of the lights circuits feed thru this module. There is a repair here on explorer forum so look for LOM repair or bypass in a search, if I recall correctly. Good luck.
