Headlight Switch: Problems with Wiring | Ford Explorer Forums
m1shooterva
1997 Explorer
I recently acquired a 1997 V8 AWD Explorer and it failed inspection b/c running lights wouldn't light. I finally troubleshot it to the headlight switch, found the wires, connecting harness, and switch were melted. Replaced the harness and switch (soldered and shrink wrapped each wire) but have the same problem.
I think whoever "fixed" this before might have cross-wired the connector wires? So I'm in need of a drawing or pin out diagram that shows me the switch connectors, their function, and color coding. Can anyone give me some insight/wisdom/knowledge about this problem? I've read in other forums where this switch problem seems common?
Thanks in advance.
Do you have daytime running lights?
Yes but when I go to headlights I lose them and the dashlights
Great source for wiring diagrams.
Auto - Online Repair Info
http://search.ebscohost.com/
Login ID: rrcc
Login PW: rebsco
Select: Auto Repair Reference Center
Fill in: Find Your Vehicle
Follow prompts down to Wiring Diagrams.
login and password no longer working
New info: Login is chattech; PW is avenue.
I tried the login and password. didn't work. thanks for sharing this.
UN springfieldmb
PW volunteer
UN springfieldmb
PW volunteer
Got an updated login for the wiring diagram link? Trying to track down the park lamp relay location on a 2008 Sport Trac
Sorry, I don't. I think I just dug online and found those...
EBSCOhost Login
Login ID: rrcc
Login PW: rebsco
Those Logins are dead... but found this one and it works but can't seem to find the section to look up wiring diagrams?? Any help? Looking for wiring diagrams for a 2002 Ford Explorer??
Thanks
User ID: ns321918main
Password: orcharter%342
