frstxplorer
- November 9, 2005
- Stafford, Ct
- 93 xlt
Ok im stuck my head lights keep turning off and on by them selves it started with the high beams only, theyd come on and be ok for awhile then all of a sudden theyd cut out, switch to low beams it was fine after a while you could go back to highs for awhile. then it started doing it on low beams.
Ive changed the c.b. in the fuse box checked the maxi fuse in the power dist. box and checked the plugs at the head lights its acting like a relay but there isnt a relay for the head lights dont know if I should try a bigger c.b. ive got a 20amp in there no Thanks In Advnce For Any Help ~DREW~
