F14CRAZY
To the flo...
- October 31, 2002
- Dimondale, Michigan
- '92 GT, '93 Limited
Howdy. I once read about 2nd gens having an electric valve on the heater core hoses, that would stop coolant flow to the core when the air con was on, since there's still a little bit of airflow going through the core. Turning off coolant to the core would result in cooler air con.
Is this simply a shut off valve on the inlet hose? (I think it's the one nearest the driver's side). Or is it more like a bypass, like a water softener? Anything will help, with it sometimes getting above 100 here in mid Michigan
