Heater Help for a noob :) | Ford Explorer Forums
Kid_Joe
Salt Lake City, UT
2000 Exploder Sport
Couple questions about my heater system, first where does the water temp indicator usually run for the OHV 4.0? Mine is running pretty close to the low side,, and I notice that the heat coming from vents, with the temp controller set to max hot, isn't all that hot? I'm kind of thinking I may have a stuck T-stat? any thoughts or suggestions?
Thanks in advance!
Thanks guys, I think I'll give replacing the T-stat a try, mostly because the heat does come when the temp comes up..
That definitely sounds like the thermostat. My Explorer was doing the same thing...got a new thermostat and all is well, plus gas mileage went up 4 MPG to 18 MPG mixed driving.
