heavy vibration | Ford Explorer Forums
heavy vibration
rfaulk93
Augusta, GA
2001 Ford Ranger Edge 3.0
Hello
So after doing a transmission fix (which worked perfectly btw, thanks to the valve body rebuild diary) i was driving to dump oil
well then the fan belt snapped, nearly took a tranny cooling line with it
after getting the new parts and fixing the belts, i went to test drive
when i turned the wheel i got a Car shaking vibration, more prevalent when turning to the right
I got my mother to turn the wheel while i watched the belt and i could see the tensioner pulley move back and forth at the same cadence as the vibration.
It is so bad it rattles the plastic of the dash!
any ideas what it could be?
does it at all speeds
Engine vibration im guessing?
Get the codes pulled.
