Joes4x4Ranger
- August 7, 2006
- The center of Hell, Parker, Arizona!
- '91 XLT
I've got a heavy vibration at highway speeds in my 4X4 '91 4 dr. I'm running BF Goodrich 31X10.5's on NEW alloy rims a 2" suspension lift and Duff radius arms. The vibration starts at about 65mph and gets worse the faster I go, at 70-75mph it shakes my teeth loose. I feel it in the seat as well as a slight shimmy in the steering wheel. Below 65mph this rig is smooth as silk. Here are some of the things I've checked so far.
I had the tires balanced at 2 different shops about an hour apart. I watched both times and saw no signs of out of round or "wobbly" tires. Both times no weight was needed tires were prefect.
Rotating the tires has no effect on where I feel the vibration.
I checked the steering linkage nothing loose. Ball joints are new. Front wheel bearings packed and tight.
Shocks seem to pass bounce test ( I get it rocking and let go, it comes up once and settles) and show no signs of leaking.
It's not an ignition miss at high speed, I drop the throttle and the vibration continues till my speed drops below 65mph.
U-joints are new just replaced them a couple weeks ago.
Transmission mount looks good and feels tight.
Alignment as follows: Caster L 3.75+ R 4.25+ Camber R .50+ L .50+ Toe is 1/8" IN. The caster is well within the specs printed on the sheet I got from the shop, max + caster is 5.25
I'm out of ideas, the tire shop will not replace the tires cause they balance up, show no signs of separation, and are wearing perfect. HELP!!!
