nailhead_sled
- April 1, 2004
- Toronto,Ontario
- 1998 XLS
How did I screw this up?
Mounted everything per directions- except for the green wire from the switch, which I tapped into the accessory wire from my head unit.
Re-connected the battery, and nothing works. No light on the toggle switch, and my stereo won’t even turn on. The stereo will flash the time- so the constant feed is still good, but with the key in the on and acc positions I can’t even power up the deck.
I disconnected the tap to the acc wire and re-connected the deck and still nothing.
How could this have affected the stereo?
The only thing I can see I have wired wrong is the toggle switch as the directions do not indicate which post are to be connected to which wires ( 3 post switch- ground, green ‘to lights’ and the yellow wire to relay post #86) but surely this has no bearing on the head unit.
No lights, no stereo = one bitter individual desperately seeking assistance.
