Crunchy
- March 27, 2008
- Ottawa, Ontario
- Ranger 03 XLT 4L SOHC 2wd
I have had my Hella 500's (2 of them) for 2 years now, now issues at all.
I wired them with a relay, switched inside the truck. Power for the switch comes from my radio harness....relay powered right from battery.
I was driving overnight last night, used the lights, turning them on and off as oncoming traffic approached me...no problems.
Then 3 hours into my trip (it was about 4am) I went to turn them on, my truck had a severe misfire, my cruise control deactivated itself, my ABS, check gage and "Theft" lights started to blink. Kept backfiring for 2 seconds until I turned the lights off. Lights off, all was fine. Tried lights again a few minutes later, same issue. Scared the life outta me (middle of nowhere at 4am).
With lights off, no problems at all....Later in the morning I tried the lights again when I was near civilization, and everything worked fine.
Huh? Where do I start? I checked all connections, traced all wiring, all wiring is protected by wire loom, all connections are soldered solid, nothing frayed, nothing melted, harness is fused literally 2 inches from the battery.
Where do I start?
Where do I start?
