Hello!!! need help | Ford Explorer Forums
Hello!!! need help
cathyvan
southaven,ms
2004 ford explorer
just replaced both cylinder heads on my 2004 ford explore sohc, the time chains were not taking off, but the timing had moved after the left head camshaft bolt was being taking off, the new heads are on and need help on getting the setting back to the right mark. but with the new heads and over head cams, not sure how to do this to make sure they all line up right, the #one cam is all the way to the top and the #5 . but the two dots on the balancer shaft sprocket are not lined up to the hole on the reversal shaft at the bottom for the timing, does anyone have a solution on setting this right?
