ajbrowning
- August 23, 2010
- On the Lake, Ohio
- 1995 Explorer ATX 4WD
Hello all, I recently purchased a 1995 Ford Explorer, 4WD Automatic. Had a few issues at purchase that I knew about. Has to clean the MAF Sensor, was going to clean the IAC Valve, but had to replace it, etc. Mostly all minor stuff. Still need to do the TP Sensor still. Don't mind about these things.
Here is my issue. When I got the Explorer, I knew it had a delay shifting into drive, didn't think it was that major of an issue at first. Yesterday, I was driving it for a couple hours, and when I was close to home (about 5 miles away), I lost all forward drive (on the highway). I still have reverse, but no reliable 1st, 2nd, 3rd or OD. I had it towed home, and let it set completely off all night. This morning I tried driving it in forward, i can get a little 1st gear, but nothing I would rely on to drive it anywhere. When I first started researching the issue, I thought that maybe it was a Vacuum Modulator. Well that part apparently ended with the A4LD tranny. I have the 4R55E Tranny from everything I can find out about the truck. So if there isn't a Vacuum Modulator in the truck, and the problem seemed to have been fixed in the A4LD by replacing it when there was this issue, what would cause the same thing to happen in the 4R55E?
I am not sure if this is related or not, but a couple weeks ago I had an issue with the radiator overheating. There was a small leak in the radiator (fixed now), and at one point, I had very little antifreeze in the radiator from it. This lasted for maybe 5-10 minutes of driving before that issue was corrected. Found out in that repair process that the last owner removed the thermostat, and never replaced it. I put a new one in, fixed the leak (weldable area) and refilled everything.
All Fluids are good in the truck. Need to check the color and smell of the ATF, but the level is good. So what could my issue be? Had one person tell me the bands could be warped, and that I would have to have the tranny rebuilt (1500-2000 where I am) and I don't have the money for a rebuild. I am going to do a tranny flush and filter change tomorrow. But I have a sinking feeling that that will not fix my issue. What else could it be? Any advice will help. I am not that proficient with working on trannys but am pretty comfortable doing any work on my truck with the right guidance.
Thanks everyone.
Thanks everyone.
