HELP! 3rd row dome light removal | Ford Explorer Forums
please help! Does no one know how to remove this dome light?
I think the plastic cover pops off and then there are screws. Look for tabs to insert a flat head screw driver.
Ok I will have a closer look this evening and get some more pics
Thank you for the help
If I remember correctly, there is 3 plastic clips 1 towards the front of the car, 2 closer to the back on the sides, but I could be wrong. This cover is pretty tough, but I think I also had to pull mine to the side a little bit, mine was pulling the fixture with the cover as well, so it made it harder to remove.
I got mine out to replace the bulbs with LED lights but I forget how I got it off.
