tradar
- July 12, 2007
- Muskegon, michigan
- 1999, mountaineer
I am doing a convertion from a push button 4 wheel drive, to the stick on the floor. I have everything,
BUT:
I have found a small problem:
The 94 drive shaft has (I Think they are called "velocity joints" , two u-joints put close together) velocity joints that are bolted to a connector right at the t-case. The replacement t-case has a yoke that slides into the t-case.
Do they make a t-case that has veloctiy joint connections and still is manuel shift?
do I just have the wrong t-case for my applaction?
(sorry I can't spell worth a crap!
Thanks for any help.
BUT:
