KC
- February 6, 2004
- Pittsburg,CA
- '01 EB SOHC
I have searched but haven't found anything to help me yet, so here. we go. My son has a 96 X with a 4.0 OHV. Apparently it has been rough idlng & missing for awhile (NOW he tells me!) but it got worse recently and threw a P0302 code. I tried driving it and found that under a load, it runs like CARP!! I have tried several things but the problem presists. In sequence I have done the following:
Swapped the plug wire with #1 - no change.
Swapped the plug with #1- no chage.
Sprayed starting fluid around the intake and did not hear any change in idle speed.
Started thinking injector but was dismayed to find the injectors sandwiched between layers of the intake manifold (???), so I tried the Seafoam thing with half into the intake via the PCV valve (I know, that doesn't go through the injectors) and half into the tank wich was only 1/3 full. Still no change but there hasn't been many miles put on it yet.
So then I realized that while I couldn't swap the injector easily I could unplug it, so I did. The rough idle symptom only got worse. Plugged it in, a little better. Unplugged again and ran worse. So the injector is working, although I don't know how good.
So now I'm thinking the worst - valve, valve spring, rings, head (it does not steam out the tailpipe so I'm not thinking head gasket) so I do a compression check. It performed exactly as the #1 cylinder did. First stroke 90psi, 2nd stroke to 120 so I'm thinking the cylinder & valves are OK.
Back up a bit and think "OK it's gotta be spark or fuel". I think it would be odd for one out of six in the coil pack to go bad, but stranger things have happened so today I bought and installed a new coil pack. The problem improved a bit but the misfire is still there and the P0302 code is "pending" after clearing it out and driving it around the block.
Right now it is smoother at idle and smooth just above idle but if you put a load on it such as driving uphill it is obviously misfiring and stumbling.
Any opinions? Am I looking at injectors? I have heard of someone on Ebay selling injector rebuild kits for these - any feedback on those? If I have to tear it down to get to one injector I may as well deal with them all at the same time, and if they work it's probably alot cheaper than all new one's - if the kits work.
I should also mention that I had replaced the lower intake and upper plenum gaskets (Felpro) last year for a P0304/losing coolant issue, so the gaskets are relatively new, and it had been running good.
Thanks to all in advance!
