HELP CD CHANGER | Ford Explorer Forums
HELP CD CHANGER
Biteme2718
San Antonio, Texas
Explorer 97" XLT
I spent the last 2 nites taking my car apart. I took out the stock cd changer disconected everything and rehooked everything correctly. I cleaned the changer throughly and rechecked the connection. All the wires look fine. Yet, the DAMN thing will still not work. It will cycle through all the CD's and makes a high pitch whining noise then go to the next CD. WHAT DO I DO!!!!!!!!
BEN
if all else doesn't work call radiosandmore they should be able to help you out. www.radiosandmore.com
Check your Changer cartridge
Check the slots in your changer cartridge (or "magazine") carefully. If you have at some time accidently stuffed two discs into one slot, the dividers of the magazine can become distorted, leading to loading problems. With NO DISCS in the magazine, the gaps between the dividers should appear evenly spaced. If the gap in any one slot looks larger than the others, somebody may have stuffed it with 2 discs. Once that happens, it will frequently act up, until that magazine is replaced with a new one.
Check it out.
regards,
Jeff
Thanks Jeff Ill try that
Ours did that- the laser is toast- they last about 3 years according to most repair shops. Its easier to buy a refurbed changer off Ebay or the web then to try and fix. Theres a place here in town that will sell a refurbed model for $120 with your trade in and offers a year warranty.
good luck
Hey Baja where do you live. Thanks for the info. I decided that it was my laser and i am off to find a new Changer. I would love to get a refubished one so I could keep everything out of sight.
THanks
Ben
I'm In San Diego, CA
the shop is called Auto Radio Specialist
619-234-8293
ARSSDCA@aol.com
you may want to email or call them first and ask if there still doing that but it wasn't too long ago.
