help check engine light | Page 2 | Ford Explorer Forums
if anyone could let me know how to bypass the modual so i can get 4lo i would really apricate it.
The neutral and stop are a safety feature that keeps you from slamming your t-case into 4lo at high speeds. Leave it equipped. Try doing it on time and see what happens to your t-case. Just my opinion.....
ok there is one wire that on the auto equiped ex's goes to the trans that does not in the manual ones wire harnes it obviosly gets routed under the dash somewhare it show's that it is grounded I traced the wire down with a lot of help grounded the wire and guess what 4lo works again & i still have to be stoped with clutch in & in neutral for tc to shift into 4lo so all is good.
