ajay
- December 8, 2006
- Novi, MI
- '91 Explorer XLT 2WD 5SPD
Ok so yesterday after my drive into work I shut my truck off and it started dieseling (the engine kept trying to run after I turned the key off) and continued to do this through out the day. It ran fine when I drove it and it would start up alot faster that usual. A couple guys suggested that the timing might be off and/or I was running rich and to disconnect the battery and reset the ECU. I drove home and on the way filled up and put some dry gas in the tank just in case. Meanwhile the check engine light kept turning on and off during the drive. I got home, disconnected the ground and waited 10 min and hooked it back up. Now the truck won't start. It tries to turn over but won't catch. I let it sit over night thinking it was flooded but it made no difference. Any suggestion? I'm really stuck here!!! Please help!
