baileybug
- December 8, 2006
- fairmont wv
I have a 1993 explorer, it will idle ok, but when you drive it and slow down you have to drive with 2 feet or it stalls after it has set for a good while it will start up idle fine. I had the ignition module tested it was ok, back in may had the injectors cleaned, new fuel pump, and a tune up. the engine light does not come on, is there anyone out there that can help. I am running out of time before snow hits us and then I am stranded.
