HELP!! Fog light problem... | Ford Explorer Forums
03ExplorerSPT
Quincy, IL
2003 Sport XLT Premium
Ok so tonight when I was out I turned on my foglamps. All was well. I switched between high and low beam a bit and as we know the fogs only come on with the low beams on the '95 model (unless you've done the fog light mod). So when I get home I realize that when I hit the fog lamp switch to turn them off the little LED wasn't showing. So I was like s**t!! So my guess is that the fuse blew. Am I correct?
Also, I should note that I did pull the left stalk back to turn on the highs with the lows and fogs for like 5 seconds. I've done this before with no effects. If the fogs are on a different fuse, which apparently they are I'm guessing, could using all the lights at once blow the fuse for the fogs since it not even on the same system? Sorry for the long post and all the questions. I really would like to know all the info though.
Also, my mother is being weird about it. She was like, "Do your headlights work?" I say yes. So she says, "There you go. You don't need fog lights." I was like whatever. I hate it when she does that. She doesn't even understand why I would like to add things to my truck. Makes me sooo mad. Thanks for letting me vent and please try and help me with the questions.
1995ExplorerXLT
Originally posted by 1995ExplorerXLT
... Also, my mother is being weird about it. She was like, "Do your headlights work?" I say yes. So she says, "There you go. You don't need fog lights." I was like whatever. I hate it when she does that. She doesn't even understand why I would like to add things to my truck. Makes me sooo mad.
That's what moms are for. LOL
Sorry bro. Are you using a relay to power the fogs?
Ok thanks for the reply but, I was just a complete dumba** last night and didn't realize that the reason the fogs didn't work is because the highbeams were on. This morning when I saw the light for high beams on I felt really stupid. :confused:
So I had one of my moments and just please don't make me feel too stupid. :p
