Drummer1
- February 8, 2010
- Cave Creek ,Az
- 2002 XLT 4.6L Limited
Hey all, its been a while since I have posted/asked a question and well the old girl is having some issues. I am at my wits end and its not a very long wit.
Started the a/c up a few weeks ago and within a 20 min ride (mostly freeway) she was overheating (in about 103-105 degree weather, she did fine last year in 111).
Replaced, water pump, fan clutch ,radiator, t-stat, new serp belt(all parts are Oreily's as that's what I have to work with), by-passed the heater core, flushed the system over and over with the hose and Prestone flush (it was filled with crud due to some dumbass mixing orange and green, I wont even go into it here),I did not see oil in coolant or any white smoke from the exhaust (no smell of exhaust in overflow tank) replaced coolant with 50/50 mix.
Air condenser fins don't seem to be obstructed by anything and space between rad and condenser is free of debris.She overheats weather the a/c is on or not (with the a/c on just overheats quicker), highway or surface streets (it takes about 20 minutess until it's at the halfway point on the dummy gauge) it makes no difference she gets a little hotter every mile , gauge is moving up and down in small increments like the t-stat is opening and closing ,but, the needle will go over the halfway mark for a bit then back to just before half (normal temp, needle is at about 11:00 even in 111 degree heat) I can let it idle and it will cool down slowly, so needless to say, I'm completely stumped!
Could my hoses be collapsing and restricting coolant flow even at slower speeds? Could it be an airflow issue? I have no clue why this is happening,i hope I covered everything that's happening, this truck is my way to work(not to mention I really like her
) so if anyone has any ideas I welcome them
- thanks!
