Help im stumped. | Ford Explorer Forums
Help im stumped.
EXPLODER 69
Jackson, California
1995 xlt
last night i was headed home and started to go from a stop sign and the car really bogged down and died. it now is still sitting on the side of the road. it was rainy. do i have a no fuel problem or do i have water in my intake?
If the engine oil is clean and engine still turns over I would assume you have other issues such as fuel supply pressure or ignition to start with. Check the basics first - spark, fuel pressure, compression! I take it you have a good fully charged battery?
If the engine oil is clean (not milky looking) and engine still turns over I would assume you have other issues such as fuel quality/supply pressure or ignition to start with. Check the basics first - spark, fuel pressure, compression! I take it you have a good fully charged battery?
i found out it was the fuel i put in it. i will never go to a safeway gas station again. there was a lot of water in my fuel. i had to completely drain my tank and start fresh. i think safeway should give me my money back
file a complaint with them if you can document that it was running fine before you got fuel but after it quit and you have proof that it was water in the fuel they should pay for the repairs. They also need to know so that they can determine if they have a leak in their tank or if they got a load of bad fuel.
