imq707s
- July 5, 2000
- Springfield, Missouri
- 1997 Mercury Mountaineer
I've got a 97 ext explorer. How hard is it to replace the seal on the front differential where the drive shaft mates to the pinion gear? It's leaking a little and I would like to fix it before it gets worse. Will I need to remove the gears out of the housing and take out the pinion gear before I can change the seal? Any advice would be great, thanks.
