srvblues00
- November 22, 2001
- Denver, NC
- 94 Sport / 88 Turbo Stang
Around 63 to 75mph, my X shakes pretty badly. Enough to cause a full drink in the console cup holder to splash over. I got my X last November, and it was not shaking then. I have since had the center link replaced, I replaced the radius arm bushings, installed Monroe Reflex shocks, and had an alignment. I have no idea how long centerlink and radius arm bushings had been bad before I got the X, but it had caused uneven tire wear on the front. After all the above had been done, I rotated the tires, but the shake was still present. Do you think uneven tire wear could cause shaking this badly? Or do you think another suspension component is going south? If the front end is supported by jackstands, I can grab a front wheel and it will rock side to side slightly. if I grab the top and bottom of the wheel and try to rock it back and forth, it's rock solid, so the wheel bearing should be fine. Also, the steering seems kinda sloppy, but I am used to driving Mustangs, so it might just be me, but even Dad seems to think it's a little non-responsive. Any ideas?
