drumminforev
- August 8, 2006
- tucson
- 97 none
My customer has a 1997 ford explorer 6 cylinder. His compressor locked up, so he had someone replace it and recharge. It only cooled to 68 degrees because it cycles. I hooked up my gauges, and concluded that its the low pressure cutoff switch causing this. At an idle, it will stay at a constand 45 low 175 high.
When reved to 2k rpm, the low will continuously drop steadily til it hits 20psi, then the switch shuts it off, and it repeats.
Now, I am assuming its either the orifice tube that got clogged when the compressor locked up or the accumulate is clogged.
What do you think?
Also, I CAN NOT figure out how to remove the accumulator, and I can not locate the orifice tube or figure out how to take apart the evap box.
Here are the pics of the piece of the accumulator and the fitting I cant understand. Someone, let me know how this is supposed to come on and off and if a special tool is needed.
RECAP
Help me disconnect the accumulate.
Tell me where the orifice tube is located and how to remove. I have the tool.
Help me diagnose this problem, whether or not I am correct.
What do you think?
RECAP
