HELP! My power windows stopped working. | Ford Explorer Forums
nscheidl
Edmonton, Ab
2004 XLT
I have checked all the fuses, and even replaced the p/w circut breaker. I'm trying to avoid a hefty garage bill, any suggestions?
welcome nscheidl did u check the motor on ur window maybe it stopped working
Hi, no have not checked the motor, this is what i'm hoping to avoid, then it'll have to go to the garage. I'm hoping it's the relay but dont know where to find it!
hey nschedl
u just wrote a post just now and it don't show that u wrote a post it says u got 0 posts it should say u wrote 1 and it says 0.
I dont what happened to my post, but i havent checked the motor yet, i;m trying to avoid that, it then goes to the garage. I hope its the relay but I dont know where it is.
Power window
Further to checking your drive motor, just try to listen while you try to operate your window, is there any noise? is so its mean motor is working but plastic gear in side power window unit is slipped, then you have to open your door from in side & approach to this unit, not very complicated but needs bit time to do, I have done this excersise with one door second is still panding,
Cheers
there is no noise at all, all the windows just stopped working.
Welcome.
Welcome to this forum! I've moved your thread to the stock 2002-2005 section. Check your switches, and the ground connection in the door. There is a bulkhead connector behind the kick panel that occasionally gets a bad connection. The other possibility is a broken wire between the door & the frame inside of the rubber cover.
I must say it's not the motor in your case if all of them just gone dead, its got to be ground , common lose connection, control switch which is controlling all of four windows, or may be the fuse holder if not fuse!!
