Help needed 97 4.0L Auto Sensor Location | Ford Explorer Forums
Corny1
Australia
98 xlt
Can someone please help me with the location of the 2 x 02 sensors and how to access the top plugs ! I took the truck to my mechanic to have the 02 sensors changed as i was getting Code P0155 , After the so called change the ommision light came back on so i decide to inspect it myself. Turns out all he did was cut the wires remove one sensor and re solder new as im assuming he couldnt reach the plug to remove and replace whole sensor.
Thinik i will do it properly myself just need some advice.
2 sensors only ?? How to reach , access top plugs??
Thanks in advance
And he calls himself a mechanic huh? I hope you didn't pay him.
Go back to him and tell him he has to go through the access door under your console from the inside. It sounds bad but it only takes about a half hour to do. He probably spent that much tme trying to get to one of them.
Turdle did a great thread on how to access the panel.
http://www.explorerforum.com/forums/...d.php?t=209770
