nonhog
- October 23, 2009
- Pacific N/W
- 2000 Explorer sorta
Short story: Can someone get a location of the RH (pass) side O2?
Measure from where the engine/trans bolts together.
Long story: I am doing the world slowest engine swap. 2000 Explorer 5.0 into a 1980 Volvo. What I have found is the O2 wire harness has 3 connectors on top of the transmission. I believe the one I want to use on the RH side is the blue connector (closest blue connector that is)
I am only using the forward 2.
What I am finding is where I added the O2 bung is too far forward and the sensor will never reach. Before I weld another bung I want a ballpark to use as a guide.
Space and exhaust routing is for sure different in a Volvo, so exact measurement is not necessary.
Thanks in advance!
Thanks in advance!
