doublebubble
- November 24, 2009
- Forest Hills, NY
- '96 Explorer Eddie Bauer
Greetings to all! I'm a new member to this forum, who recently purchased a '96 Explorer, (Eddie Bauer edition) with 105,000 miles on it. My problem is that the transmission is slipping, and is not shifting gears. I put the car in drive and it doesn't catch so I drop it to low 2, and it catches and I put it back into drive. By the time it gets to 3rd gear its not catching. I am able to drive the car, but it's getting worse, and sometimes the overdrive light indicator flashes. Also, the check engine light just came on recently too.
Today I went to autozone and here is what the scanner said:
PO 761
Definition:
Shift solenoid 3 performance condition
Explanation:
detected a mechanical fault with the solenoid energized, valve stuck off
Probable cause:
1. Mechanical condition-solenoid stuck
2. Internal transmission problem
Can anyone help me understand what this means?
Also, I live in Queens, NY and would very much appreciate a recommendation to a honest and legit mechanic who can fix my transmission problems. Thanks in advance!
PO 761
Definition:
Explanation:
Probable cause:
